RealFlight G3 Add-on problems
Hi
Apparently there is a known issue with at least the first two Add-ons for G3. If these Add-ons are installed using the default settings, the new planes and flying fields etc will not show up in G3. I had this problem when I first got G3 and the first two Add-ons. At the time I called Real Flight and they had me make a change in the directory where the Add-on is installed. Now, some time later I am recovering from a PC crash and Windows XP re-install and I can not remember what they had me change during the installation of the Add-on. Problem is, the Real Flight technical support people can not remember it either.
So, software that was once working can no longer work. The original installation of the Add-ons was problematic but at the time the technical support team knew right away what the solution was and stated that it was a known issue. So, since they can not remember the solution I am hoping someone else can. If you know the solution please let me know.
thanks,
Monte
