RCU Forums - View Single Post - Hitec or JR digitals ?
Old 11-02-2002 | 02:21 AM
  #41
MrDHEJ
Default Hitec or JR digitals ?
Originally posted by Robert300XS
You do realize that standard servos are plenty, right? Thoes servos are going to be a big waste of money on that SE... Believe me, I have 2 SE's, both with insanely large tail surfaces and the standards still seem like they can handle quite a bit more. Just going to HS-525 is pushing it for the SE
Yeah, the 5925's are probably overkill for the SE, but i have 6 just sitting in a box atm. I Found that the 5925's were to fast for throttle servo's on my 1/10 scale cars and replaced them with the 5945's. The nicest thing about the 5925's is when you flip that control to one side the servo goes to that side right now! And at 7.5 Kg/cm at 4.8 volts it's not weak either.
Did you modify your SE's with larger tail surfaces? Or just that the SE already has large fins.
