Originally posted by WreckRman2
First you say that you have had 3 failures, then you say you have had zero failures... Are you saying that just because you found them on the bench and you didn't lose a plane that it wasn't a failure or a problem with the servo?
Maybe I misread something here but you contradicted yourself.
David
I was attesting the fact that we have zero failures in GS Models which have been used and abused regularly... I should have prefaced the statement, however I thought it was obvious...
More specifically as outlined I/we are not using the 5600 series in GS models. Yes, three 5645 servos did fail. None were mounted in GS model's as noted.
You seem to have missed a major component of my post, which was relative to the number of actual verified failures of servos. Given the number of JR servos I/we have had fail the three defective servos from Hitec is of little concern to me... If I had to guess the ratio would be somewhere in 20% range of wear/failures with JR and less than 2% with Hitec.
