RE: Aresti 40 info
This plane flies nicely. The gear is too short for most engines swinging larger diameter props. I always fiberglass center sections of the wing joints past the fuselage sides which would be recommended for this plane. If you have a computer radio set up spoilerons for landing. This plane is aerodynamically clean and doesn't slow down well landing (as most planes of this type are). A larger diameter lower pitch prop will help keep the speed more constant and slow the downlines. Check all glue joints you can get to. (This goes for all ARF's). Let us know when you get it in the air.
EXCAP232
