RE: outrunner mounting
Hi Allen, both will work great, Im not sure what part your referring to as the gooseneck foam piece? But, to mount a outrunner radial you will need to glue a ply disc in the nose, cut the torqued motor mount back a little so the prop will still clear the nose, then glue the ply disc onto the nose against it and all fuse sides.
Hope this helps.
