RCU Forums - View Single Post - I need an engine for a showtime 4D!
Old 10-07-2005 | 11:58 AM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: I need an engine for a showtime 4D!
You can run a 4-stroke inverted.
I have problems with 2-strokes--but I've run 4-strokes and seen others run them inverted too.
Just use the OS F plug and tune the low end right. They work great inverted.
Some common problems:
The carb/intake tube tends to get flooded when your fueling--so use a pair of Hemostats or some other clamp to pinch the fuel line going to the carb when your fueling.
Not leaning the low end enough. This is a lot of the problem guys experience with inverted engines.
Having your tank too high above the CL of the carb. If it's close---on a 4-stroke---your gonna be fine. But if the tank CL is more than 3/4" above the CL of the carb--you'll suffer many hours of grief.[&o]
Just use an F plug and try and get the CL of the tank close to the CL of the spraybar. It'll work great.
2-strokes inverted-----don't even get me started[:-]
