RCU Forums - View Single Post - Double Taco
Thread: Double Taco
Old 10-07-2005 | 12:46 PM
johnyh
Default RE: Double Taco
Fus construction and progress photos
A slight deviation from the instruction with the use of carbon fibre tube instead of fibreglass tubing. Other than that construction followed the instruction manual.
On completion of both frames these were taped together and any "highs and lows" sanded out.
As expected when "scratch building" discrepancies do occur, check the joint to the wing. This required some "balsa bashing" to get a good close fit.
ID:	335440   Click image for larger version
ID:	335441   Click image for larger version
