RCU Forums - View Single Post - P51- TRAINER FROM HORIZON
Old 10-07-2005 | 03:03 PM
  #102
Pit-Viper 1's Avatar
Pit-Viper 1
My Feedback: (12)
Default RE: P51- TRAINER FROM HORIZON
A couple of the pro guys that fly with us noticed this also on my take off, they said to try and shim the motor mount just 1mm at a time (to the right) to see if this helps. They said they do this on their show planes to get rid of torque steering. I agree with the flywheel maybe being the coulprit so I put in an OS .50 to see if this will cure it. My firewall was smashed in a little on the right side so I don't need to try to shim it right now, our best measuring showed it to be between 2 - 3mm off set as is. Hopefully it flies otherwise it's starting from scratch here. I will let you know as soon as I get some time on it this weekend. Later
Shane
