RCU Forums - View Single Post - Katana instructions incorrect?
Old 10-07-2005 | 08:43 PM
FallingWithStyle's Avatar
FallingWithStyle
Default Katana instructions incorrect?
Well, I guess the Katana instructions on the CD aren't for my Katana PRO kit.
The only Katana instructions to be found on the CD say to install the siderails in step 4. Which I did with great care. I guess this is wrong for a PRO kit, because I can see right away I won't be able to slide the laminated wing into the now narrow fuse slot.
What should I do now? My wing isn't built up yet. *Maybe* I can slide in the single layer wing and add the skins after. But its going to be very tricky to keep the wing straight doing it this way. Sanding down the leading edges is going to take longer for sure since the fuse will be in the way near the root ends.
Has anybody recovered from this error? Any tips?
What instructions should I be following to build my Katana S Pro? I don't see any relevant help files on the CD but maybe I'm overlooking something...
Clark
