RE: Tucson sequences
Saturday Unknown for invitational.
Come in the box from the left. Pull up and roll right twice (45 degree up) first part of reverse shark tooth. Opposite snap. Push down, 4 of 8 exit up.
Go well past (if wind is coming from left). Pull vertical figure N. 4 point roll up, 1 1/2 neg snap opposite 2 point roll on 45 downline, pull vertical 2 point roll, don't build too much speed because...
Figure 6, one postive spin at top, 3/4 inside loop, 3 of 2 point roll, same direction 1 1/2 pos snap to inverted, mid level.
Rolling circle left box, 270. outside, inside, outside. Push at center, quarter roll on upline, hammer head, pos snap on downline. Exit up.
Tailslide, now one roll up watch the nose carefully. I love the Radiowave Extra 300. I love this sequence. Its all in my head, but I know its going to go well.
Tailslide, wheels down, 2 of 4 down.
Next is a goldfish, two point roll on 1st 45, followed by 1 1/2 pos snap same direction. 3/4 inside loop, 1 1/2 rolls on 45 upline, exit inverted high.
4 point roll half loop, 8 point roll.
Pull 45, 2 point roll, half inside loop, neg snap opposite roll and a half exit up.
Pull 135 degrees to a 45 degree upline, two neg snaps, teardrop, push 5/8 outside loop to vertical downline, neg 3/4 snap to the right. Exit upright cross box.
That's all from memory. I'll check with Kevin before flying tomorrow in case I missed anything.
Cheers from Tucson. Somone is staring at me, time to log off the computer.
Don
