RCU Forums - View Single Post - Building a Sig 4*40....please support
Old 10-07-2005 | 10:59 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Building a Sig 4*40....please support
While the best would to have had the spar sitting in the "bottom" of the notch in each rib, it's not going to be a big deal if not. You would probably cause more damage by trying to remove the spar than if you just left it. Since you're using CA for your build, run a bead of thick CA where the spar and rib meet. Or even a small bead of 5 minute epoxy will do better. Just get something there to stabalize the spar and rib. You'll be ok. Chock it up as a learning experience
Ken
