RCU Forums - View Single Post - Engine won't run with throttle barrel fully open.
Old 11-03-2002 | 06:46 AM
canadagoose's Avatar
canadagoose
Default Engine won't run with throttle barrel fully open.
Usually when an engine quits when opening the throttle barrel,
the low speed needle needs to be screwed out more. I know some of the smaller engines don't have them. Maybe the carbs leaking in air somewhere making the mixture too lean.
Hope you find the problem.
