RCU Forums - View Single Post - Engine won't run with throttle barrel fully open.
Old 11-04-2002 | 07:10 AM
topwinguk
Default Engine won't run with throttle barrel fully open.
Thanks for the info guys, will try all those suggestions. As AQ500 says, I also won't be buying any more LA's. Do you reckon that with the needle valve remote from the carb there is less suck?
Tony
