RE: Roto Start
You can delete the extras posts.
mulletman, if you use the electric drill it will need to turn at least 500 rpms (faster is better) and be real carefull of hydrolocking because you won't be able to "feel" it when it happens.
Forgot to add it might be better to get a starter box instead. You can only use the Tiger drive on the CEN engine and if you upgrade to an OS you will have to buy a new Tiger drive but with a starter box you will be able to use it for both.
rolland
