RE: Reciever won't work
Quazzy
Check the model # of your Gws Rx. As some above have indicated You need to confirm that your Rx is a negative shift version. GWS and other manufacturers provide Rx's in both positive or negative shift to match the buyers Tx shift, both must be of the same shift or either the Tx or Rx must be selectable for both shifts. GWS sells positive or negative versions of their Rx's. In North America all Futaba Tx's are negative shift only.
This mistake of getting the wrong Rx's for their TX's is a common mistake.
John
