RCU Forums - View Single Post - Help getting PAW 80 started!!
Old 10-09-2005 | 04:40 AM
balsaworks's Avatar
balsaworks
Default RE: Help getting PAW 80 started!!
Tom,
If the screw has broken flush with the top of the crankcase, you might be able to get it out if you can get hold of a really thin file (you probably need .02" or less), and then file a slot across the end of the screw.
You should then be able to remove it with a jeweller´s screwdriver.
You will have to file a bit into the crankcase too, but what the heck, if the alternative is to scrap it?
You can get spare screws from PAW in England.
The photos below show a broken needle that I got out of a ST carb with this technique, maybe you can use it too?
Tomas H.
ID:	336330   Click image for larger version
ID:	336331   Click image for larger version
