RE: Multiplex Magister RTF
Not sure how many amps I'm drawing but using an 11x7 prop and the ESC should be able to take up to 60amps momentarily and 40amps continuous...How do I find out how many amps I'm drawing? It really is a big problem as motor cuts out on each flight at some point and the ESC beeps. It's causing a lot of hard dead stick landings...and the magister is looking rather worn out.
Thanks for help
