RCU Forums - View Single Post - Balancing low-wing plane
Old 10-10-2005 | 11:57 PM
Ernie Misner's Avatar
Ernie Misner
Default RE: Balancing low-wing plane
On your little 40 size plane, turn the plane upside down and screw a tiny eyebolt into the very center of the wing, and on the recommended CG. The teeny eyebolts are available at arts and craft stores for picture frames I think. Hang the plane from a string. It will amaze you as it appears to be flying upside down. You can check the lateral balance at the same time this way!
Ernie
