RCU Forums - View Single Post - Panel lines help!
Old 10-11-2005 | 01:57 AM
mR JoLLy's Avatar
mR JoLLy
Default RE: Panel lines help!
The tape you are looking for is from a company called "Letraset" and the tape is branded "Letraline".
I have 1/64" (0.4mm) with part number 471.
Looking at the main web site the 0.4mm tape is no longer available, next best is 0.5mm which should be OK. I am sure with more than 2 minutes on the net with this information you should be able to find some. You might have to get it in from overseas.
[link=http://www.letraset.com/uk/template1.asp?catid=3495&viewtype=all]http://www.letraset.com/uk/template1.asp?catid=3495&viewtype=all[/link]
JoLLy
Editing this because I found the 0.4mm tape [link=http://www.letraset.com/uk/template1a.asp?catid=3529&id=3530]http://www.letraset.com/uk/template1a.asp?catid=3529&id=3530[/link]
