Sig SE - Antenna wire
installed a tube,fuel line,in top of plane just behind the canopy and down to the controls,ran wire thru tube, then connected the wire to the vertical stab.Have seen outer tube of golden rod, or anything similar,installed with landing gear straps to bottom or plane then antenna routed thru it.
