Sig SE - Antenna wire
MI
Sig SE has a tube for the antenna wire that goes from the servo tray through the fuse and out the bottom back.
The plane is covered and I can't get the wire through the tube. Maybe the CA melted the tube where I glued it?
I guess I will have to route the wire another way.
Any suggestions?
Bill
Any suggestions?
Bill
TX
installed a tube,fuel line,in top of plane just behind the canopy and down to the controls,ran wire thru tube, then connected the wire to the vertical stab.Have seen outer tube of golden rod, or anything similar,installed with landing gear straps to bottom or plane then antenna routed thru it.
OH
Try dropping a needle and thread through the tube from the tail, carefully push the needle up the antenna wire a 1/4" to 1/2". Gently pull the thread back through as you feed the antenna wire through. I have used this method a few times, be patient.
MI
The tube is small, so I did not have anything that would fit through it. I will try the needle and tread and see if it will go through.
Pulling it through could work depending on how bad the tube is.
Great suggestions.
Bill
Great suggestions.
Bill
MI
Ok
Tried the needle and thread but the tube curves out of the bottom of the servo tray, the needle could not make the curve without binding.
On to the next idea. Telephone wire. Cut and split the telephone cord. The piece went through the tube easily.
But, how do I get the antenna wire connected to the phone wire?
Can't tie them. I trimmed the end of the telephone wire, It had nylon reenforcement string inside, perfect. I frayed the nylon, put on some med CA. held it to the end of the antenna wire. When it was dry, it pulled right through.
Thanks everyone.
This is the greatest hobby because the people make it so.
Bill
Thanks everyone.
Bill
IL
I had trouble getting mine through too. I straightened out the wire really well and gave it a good dusting of baby powder. Went through pretty easily after that.
That should work as long as there isn't something actually blocking the tube.
Karl
Karl
I have used a piece of monofilament fishing line to push through the tube and used the CA trick to fasten the ant wire and monofilament line together. The monofilament line is stiff and small enough to push through. Cheers
