RCU Forums - View Single Post - Sig SE - Antenna wire
Old 11-01-2002 | 05:13 PM
mscic-RCU's Avatar
mscic-RCU
Default Sig SE - Antenna wire
Try dropping a needle and thread through the tube from the tail, carefully push the needle up the antenna wire a 1/4" to 1/2". Gently pull the thread back through as you feed the antenna wire through. I have used this method a few times, be patient.
