RCU Forums - View Single Post - How far between Pump and Turbine?
Old 10-11-2005 | 12:15 PM
Woketman
Default RE: How far between Pump and Turbine?
The fuel is basically incompressible. The only issue is drag: the longer the fuel lines, the harder the pump must work (especially with smaller lines). But it would take a lot of fuel line to be a problem. You will be just fine.
