RCU Forums - View Single Post - Knife Construction
Old 01-09-2003 | 03:31 AM
  #36
m.gramling's Avatar
m.gramling
My Feedback: (8)
Default Knife Construction
Well I have an idea for the bottom of plane, but I left it off for now. Once I get it on I will post pictures. I am in the process of working on it. I might end up doing some graffics on top as well.
Gator, you know this trick. For the wingtips, not being covered. Instead of installing motor, radio gear, pushrods, clevis', then balance plane for CG and laterally. Then have to remove everything. Then cover it, then reinstall everything.
I cut a hole in each outer wing tip, once I install all my stuff. then when balancing, if I have to add weight to a wing tip, I can install it inside the wing, then cover wingtips, and I will be thru. that way I don't have any weights sticking outside the plane.
I really don't have an imagination. I got the scheme from the plane I bought off of Jeff Williams at the brotherhood flyin. I crashed the planed. But doesn' it look similiar.
