RE: Jet Masters
The key to success in static in the JWM is documentation, if you look at the score sheet 1/2 of the points is awarded by outline of the model only! they look at your model your model from about 20 feet. At this point no rivets marking or any other kind of details are awarded. 25 % of your model is again awarded on a distance of 20 feet also (markings, scale detail, etc) still no hi grade GFK will award better up to this stage as long as the scratch builder makes sure his documentation and overall appearance is accurate. The last 25% is awarded up close and there is where a high grade ARF (read money) will give you an advantage, not neccesary though a scratch builder could do just as good.
There were incredible beautiful models at the JWM with a low static score only because they had a poor documentation. The key to success is choose the right model, something close by so you can take all the photo's you need, get the proof of color, etc.
I agree on the fact that scratch building is more effort than an ARF but creating an extra class beside the 2 already present would only divide the competitors over an extra class is my opinion.
Dutchjet
