RCU Forums - View Single Post - Multiplex Magister RTF
Old 10-11-2005 | 05:48 PM
  #99
DannyR
Default RE: Multiplex Magister RTF
You would need a watt meter or an amp meter. What size AXI are you running? It could be that your motor is pulling the voltage down to the LVC and the ESC is cutting the motor off. If this is happening, the batteries that you are using just may not be able to handle the load. Are the batteries old?
Danny
