200RSS Timing Question
I have a Quadra 200RSS with Inteli-spark that continually shears the shaft keys or wants to run backwards. As close as I can find out the initial timing is 4 degrees ?. The first question is, is it 4 degrees before, or after TDC ? The next question is do the sensor and magnet go in perfect alignment or is there some offset?
Any help would be appreciated, Thanks
