RCU Forums - View Single Post - Balancing low-wing plane
Old 10-14-2005 | 07:46 PM
  #33
jrf
My Feedback: (551)
Default RE: Balancing low-wing plane
If you want to avoid nasty surprises, always balance the airplane in it's most tailheavy configuration. You should be able to figure out which configuration that is for your airplane. Since nosewheels usually retract rearward and taildragger mains are usually raked forward when extended, most airplanes will be more tailheavy with the gear up.
Jim
