RE: quick charging hitec optic 6
As mentioned JR is the only one using a centerpin negative on their Tx charge jacks. However the inside, outside diameters on the tx jacks of the Futaba and hitec are not the same. The real problem here is using the fast charger through the TX jack will not allow the peak detecting circuits of the charger to function. The Hitec battery is easily removed to charge on a fast charger.
John
