RCU Forums - View Single Post - Reflex XTR Hovering
Old 10-15-2005 | 10:53 PM
rbushman3
Default RE: Reflex XTR Hovering
I did it today!!!! Finally, I can now claim i can hover or torque roll. I had a few of them that were 30 secends and longer that i flew out of on my own. Not sure if anyone else cares but it was defenitnly a rush and confidence booster even if it is only a sim. The two biggest things that helped me were: 1.) the time expansion factor on Reflex, and 2.) keeping the cockpit, or top of plane facing you no matter what!! ( not allowing one wing to get closer to you than the other, with the ailerons.)
The time expansion factor allows you to slow the sim down, basically giving you more reaction time to think about what you need to do. A Time expansion factor of 2 was great for me because it gave me twice the time to react to what the plane was doing, which was exactly what i needed to learn. You can set the time expansion factor at whatever you want to allow more time, the higher the number, the slower the sim will run, and more time to react. With one being normal speed obviously.
When i first started to learn how to hover heli's, the hardest thing i had to learn was to keep the tail pointed in my direction at all times, no matter what. After i was able to do that the rest came very very easily. learning to hover an airplane is almost identical in the thought process of learning to hover a heli. Once you can keep the cockpit area (or top of the plane) facing you at all time, the rest comes almost automatic. Like i said this is done with the ailerons.
It was a blast, now on to harrier rolls.
