RE: Increaseing rear end traction without increasing toe in?
Well good thing I never throw anything away, I found a suitable bearing from another block to hold me off untill my replacements show up.
With the suggest rear upper amr changes the car is much more planted and easier to drive, It still a little looser than I would like off power.This means I should thicken Up the rear oil a little as you guys have suggested, or correct me if Im wrong.My tires are a little worn(50%tread) should I get a new set before trying thicker oil?
Thanks guys
