RE: Increaseing rear end traction without increasing toe in?
Hey thanks Brad. IM not quite sure whats in the center diff, It does unload to the front under power slightly.Ill probably stop in the shop sometime this week pick up some springs, oils and tires.
Alex would you suggest stiffening up my rollbar as well as the softer spring choice?
Or would that just take away any advantage in cornering I gained from going to the softer springs?I do feel the rear could be a little softer and some bumps will jump it around a bit.
Either way Its getting really hard for MTs to be apealling to me anymore, sure my truck is stupid fast(sub 9lb Vspec powered revo) but If I beat it hard(around the track) I know its going to break.That and they just dont handle good
