RCU Forums - View Single Post - .60 Seagull Extra 300 build question?
Old 10-17-2005 | 02:22 PM
jstanton's Avatar
jstanton
My Feedback: (14)
Default RE: .60 Seagull Extra 300 build question?
I plan on using only one servo for the elevator on this plane. I will be making two rods that are connected to each other using two collars. I have done this on my Dynaflite SE-5a and it works great. The servo I use is a high torque GWS S-03, it has 86oz of torque with a 4.8v battery. This also cuts down on the weight a little. After the plan is built I test my CG and if it in not correct I reposition my battery pack until I get it right. I never add any weight to the plan to get the CG unless there is no other way.
