RCU Forums - View Single Post - 7C timer problem
Old 10-17-2005 | 04:49 PM
Barry_DVRC's Avatar
Barry_DVRC
Default RE: 7C timer problem
Stripes,
I had the same symptom. The throttle position that begins the timer counting is adjustable. I had to set the "timer on" point lower (at about 1/4 throttle).
NOTE: Check you aileron operation VERY carefully after you make this adjustment. Early 7C's had a firmware issue regarding this.
All the best
Barry
