Edge 540 elevator/harrier
If you can stay ahead of the wing rock it tends to dampen it out.
Once it rolls to the right and you correct, your too late. Try to input the correction before you see the wing go in that direction. Once you have it, you'll see that it will stay solid for a while. Generally the rocking will start again. It wont last long if you can figure out when it will start to rock again and be there with the aileron correction.
