RE: Increaseing rear end traction without increasing toe in?
I didn't notice it mentioned above, but maybe I missed it. Another possibility besides decreasing the viscosity of the rear diff fluid, would be to raise your front roll center (move inner tie rod mounts vertically up one hole). Then re-adjust your tie rod lengths to get the same camber you had previously. Also, you could try softer front springs, however this may alter the vehicle's jump/bump handling.
