RCU Forums - View Single Post - Increaseing rear end traction without increasing toe in?
Old 10-18-2005 | 06:24 PM
Andrew Smolnik
Default RE: Increaseing rear end traction without increasing toe in?
If you guys are trying to increase forward traction then you can lighten up the center differential fluid. This is what I do when I am "loose" on power.
Going to a heavier center differential fluid, tends to make your buggy have more direct power to the ground, which is good on some surfaces, but on some loose surfaces it can cause your car to drift or want to be loose, on power.
