RCU Forums - View Single Post - Hottest .30 and under ?
Old 10-19-2005 | 12:06 AM
c/f
Default RE: Hottest .30 and under ?
Good Choice,
Another angle not mentioned is that HP /RPM's come at a fuel usage cost as well. I ran Jett 30, 25, they will not make 5 minute rounds on 6 ounces. 8 is needed.
The Wbra GT just barely makes it if you sandbag the start clock, and it gets a little dicey running this motor that close to a lean fuel run on stock clunk tank.
The OS 25 makes the 5 minutes no problem.
