RCU Forums - View Single Post - Quest 50
Thread: Quest 50
Old 10-19-2005 | 12:36 PM
mithatoz's Avatar
mithatoz
Default RE: Quest 50
Hi, Christie
I've finished mine with the OS 50 Sx in it. This morning made the break in procedure, and the maiden will be on this sunday if the weather will be OK. Same problems with the covering. Also you have to but the tank upside down.After break in I measured 13200 rpm with the 12.25X3.75 W APC. It's only 4.85 lb. without wheel pants. And I measured 11.7 lb. trust. Ratio is 1/2.4 Very good. But I have problems with the CG. Manual says 95-105 mm from leading edge. OK, but from where, if you go close to the fuselage you have to add too much weight, if you go to the highest point of the wing the CG becames OK. Because the wing becomes thinner root to the tip chord. Anyway all wil be solved on sunday I think. I will report soon. Please work on CG and notify me.
Thank You.
Mithat...
