Quest 50
FL
ORIGINAL: alfonsiza
I had same problems with covering with most China ARF models, my solution is to paint the plane with polyurethane clear paint, only one thin coat to avoid weight.
I paint before i assembly the model.
Was the polyurethane paint you used in a Spray Can od did you Air Brush it??
Dennis
