Sig Rascal 40 help
I am almost complete putting together this plane and had one question about running the antenna wire, it calls to run through the fuselages and out the rear bottom near the tail wheel bracket. Any tricks or good ideas on doing this? I though about using a coat hanger wire and running it through to the drilled hole at the bottom of the rear.
Philip
