 Sig Rascal 40 help >
Sig Rascal 40 help
Sig Rascal 40 help
Old 10-20-2005 | 12:26 PM
Default Sig Rascal 40 help
I am almost complete putting together this plane and had one question about running the antenna wire, it calls to run through the fuselages and out the rear bottom near the tail wheel bracket. Any tricks or good ideas on doing this? I though about using a coat hanger wire and running it through to the drilled hole at the bottom of the rear.
Philip
Old 10-20-2005 | 12:56 PM
My Feedback: (81)
Default RE: Sig Rascal 40 help
I have used a wire to fish an antenna tube first, then you can just slip the antenna wire in and out if you want to change rx. I tend to use the Deans 2 piece short mast type antenna. Also looks cool. http://www.robotcombat.com/marketplace_rc.html
Old 10-20-2005 | 02:12 PM
Wow that will definitely work well, thanks for the info as i will try to find that at the LHS or order it online.
Old 10-20-2005 | 02:45 PM
Hmmm. That Deans antenna does look cool. Gotta try that. I just route the antenna out the bottom of the fuse and attach it to the tailwheel bracket.
Old 10-21-2005 | 12:04 PM
Agree with Timoteo,just exit the fus near the rx and run along underneath and connect near the tail wheel with a hook and elastic band. Used that method for the last three years and over 200 flights. Nice plane, you will enjoy the easy flying etc.....HH
