RCU Forums - View Single Post - Adding Weights
Thread: Adding Weights
Old 11-03-2002 | 11:00 PM
smokingcrater
Default Adding Weights
before you add any weight, have you moved the battery pack and receiver as far forward as possible? It is best to avoid adding weight if possible.
If you do need to add weight, try a metal spinner, and there are also some specially made weights for the prop nut itself.
