RCU Forums - View Single Post - Adding Weights
Thread: Adding Weights
Old 11-03-2002 | 11:32 PM
TerrellFlyer
Default Adding Weights
try rkramer's suggestion first,if you must add weight try to put them in a compartment so they can't move {gas tank area} if you must mount them ,then I would drill through the weight and use epoxy or if the stick on weight just stick on then mount with bolt and locknut,if wood is thick enough, same method but a wood type screw will work,seen and had stick on weight come loose,can be a bad experience
