You are limited to the number of channels your transmitter contains. If your radio is a 5U, you will have 5 channels, a 7U, seven channels, etc.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
ORIGINAL: Steve Collins
Will I be able to use all 8 channels with the module you recommend or will it be limited?
