75mhz Module?
Hi Steve,
Yes, you would want to use the one that was made for the 3PJ series radios, the TJ which is FUTL18**. The asterisks denote where you would pick what channel number you want in the 75Mhz range.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Sincerely,
Krysta
ORIGINAL: Steve Collins
I am thinking about running some R/C boats. Is there a 75mhz module available that would work with my 8UAFS? My 8UAFS is on 72mhz channel 13.
You are limited to the number of channels your transmitter contains. If your radio is a 5U, you will have 5 channels, a 7U, seven channels, etc.
Sincerely,
Krysta
Sincerely,
Krysta
Will I be able to use all 8 channels with the module you recommend or will it be limited?
