RCU Forums - View Single Post - The New Improved Adrenalin!!
Old 10-22-2005 | 10:36 AM
  #89
Tangy Tom
Default RE: The New Improved Adrenalin!!
Hatori 693 if you can get one or 698. If you want something a bit lighter you could go for the 822 mini pipe. Just as quiet as the bigger pipes but is cheaper and lighter. I would probably stay away from the 821 manifold (meant to be used with the 822 pipe) though as they tend to come loose. You could use an Asano header but at £90 odd they are a bit expensive.
