RE: Spread Spectrum
The Problem is that the range is limited.
When you first turn it on the transmitter checks to see what frequency's are clear to use. That should work OK if you fly close to the transmitter but if you fly too high or far away then the receiver in the plane may start to pick up signals that the transmitter is unaware of and that could be a problem.
Thats the impression I got from reading about it.
