RE: tiger 2 CG
What did you put in the tail section to add that much weight for the nose? How much epoxy did you use?
I built one and it came out perfect. No additional weight at all. I have the OS .46AX as the power plant. Man, does it move!! It is such a great plane. Way to go CG!!!!
You are the first person to have a bad comment about this plane.
