ORIGINAL: tmasboa
I don't really know alot about starter boxes. My flywheel is not a gear, it is like a grippy pattern.
And my buggy is pretty low to the ground, will a starter box fit under it when I want to start it?
And how much do they cost?
You don't need to know anything about starter boxes, they are very simple in assembly and usage. Your flywheel is not supposed to be a gear and that 'grippy' pattern is specifically designed for gripping starter wheels.
The buggy sits on top of the starter box, and the wheels are way of the ground, that's probably why motopro is laughing...
A good starter box can be had from tower for about $60. Seriously, don't even consider any other starting method...
